1999-2003 Ford Super Duty & Excursion 7.3L PSD TECH FOLDER
Old Jul 6, 2019 | 12:32 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
7.3L PSD..........TECH FOLDER..........7.3L PSD
If you would like to suggest a document or link for the "7.3L PSD Tech Folder", please send Y2KW57 a PM and it will be considered.
As you are reading through the links below, keep in mind some subjects may not fit perfectly into a category.
Please scroll completely through the links, down to the "Misc Information & Modifications" section before moving on.
***Some of the information below resides on the Excursion sub-forum, but is relevant to the 7.3L PSD.***
Excursion, FTE & Super Duty Articles
Ford Motor Company Misc Information
Safety First
Decoders
Diagnostics
FORScan
Data Display Overlay Sync Software For Video
TECH FOLDER CONTINUED BELOW
Old Jul 7, 2019 | 12:25 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
ELECTRICAL
Wiring Diagrams
Alternator
Batteries
Parasitic Drain Diagnosis
  • Placeholder (Under Development) - Consolidated Content
  • Placeholder (Under Development) - Anecdotal Reports of Culprits
  • Placeholder (Under Development) - Individual Threads in Forum Archives
Starter
Ignition Switch
Glow Plugs, Glow Plug Relay, Glow Plug Control Module
Outside Rear-View Towing Mirrors Electrical
Miscellaneous Electrical
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
ENGINE
General Engine & Engine Compartment
Engine Oil and Oil Systems
HPOP - High Pressure Oil Pump, Lines, Reservoir, & Related
LPOP - Low Pressure Oil Pump and Oil Flow
Oil Cooler
Oil Filter
Oil Specifications & Recommendations
Turbocharger
HEUI Fuel Injectors
Fuel Related
Water Pump
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
DRIVETRAIN
4R100 Automatic 4 Speed Transmission
On April 25, 2021, three (3) links related to 4R100 listed below were found to be embedded with Viglink redirects, which are retained below for the record, but are not recommended to be clicked until an investigation as to how they became monetized and or redirected is complete. Once the links are determined to be safe, or are repaired, they will be reincorporated back into the 4R100 list immediately above, and these notations will be removed. Thanks for your understanding.
ZF-6 Manual 6 Speed Stick Shift Transmission
Transmission Swaps: Auto to Manual and vice versa
NP-271 (Manual Shift) & NP-273 (Electronic Shift) 4x4 Transfer Case
Driveline Propshafts
Hubs, Bearings, Wheel Ends
Front Drive Axle / Differential
Rear Drive Axle / Differential
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
CHASSIS
Steering
Suspension
Brakes
Wheels
Tires
Old Jul 27, 2019 | 03:34 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
HVAC System
Interior
Exterior
Helpful Personal WebSites / Articles Created By Super Duty Owners
Helpful YouTube Creator Videos
Using Google To Search FTE (examples)
rdlouks
Ford In-Vehicle Tech
Oct 19, 2025 07:10 PM
Stewart_H
Feb 1, 2012 11:49 PM
1973dieselhighboy
Jun 17, 2011 09:05 PM
66gpw
May 8, 2010 07:44 AM
caseys
Washington Chapter
23
Jan 9, 2008 09:32 PM
