Serpentine belt replacement
Old Jun 17, 2006 | 03:40 PM
cjspack's Avatar
cjspack
Can someone give me the baics (and "tricky" aspects, as well) for replacing the serpentine belt on my 2000 psd? While I'm at it I'm also going to replace the cam sensor, and the stock thermostat and housing with a 203 degree unit from Dieselsite. Thanks.
Old Jun 17, 2006 | 07:27 PM
hink10's Avatar
hink10
Just use a breaker bar on the tensioner, relieve tension on the belt and remove. If your radiator hose runs though the belt you will have to remove that. If so, it would be a good time to get a hose that runs behind the belt, only costs $12 or so. Very easy job. Good luck! Steve
Old Jun 18, 2006 | 04:32 AM
cjspack's Avatar
cjspack
Thanks hink10. I've read where some say the belt replacement is a pain and a special tool is needed on the tensioner, and others say it's a breeze. I did plan on replacing the run-through hose as well.
Old Jun 18, 2006 | 09:56 AM
hink10's Avatar
hink10
Take a look at the tensioner, there should be a square hole. The end of a 1/2 ratchet or breaker bar fits right in.
Old Oct 19, 2007 | 12:26 PM
ZBeeble's Avatar
ZBeeble
"Take a look" at the tensioner? I'm having trouble seeing anything down there. There is this huge cowling in the way. Do I need to move that? Or which item is the tensioner?
Old Oct 19, 2007 | 06:24 PM
Stewart_H's Avatar
Stewart_H
Look for this:
Stewart
Old Oct 19, 2007 | 06:25 PM
Stewart_H's Avatar
Stewart_H
Whomever told you it was a pain and took a special tool had no idea what they were talking about.
A 1/2" ratchet and you're good to go.
It IS a breeze.
Stewart
Old Oct 19, 2007 | 06:32 PM
Greywolf's Avatar
Greywolf
Look around and see if you can spot the belt routing diagram under the hood too. It beats having to figure it out if you forget exactly how it ran.
Old Oct 19, 2007 | 06:54 PM
Stewart_H's Avatar
Stewart_H
Accessory Drive— 7.3L Diesel Engine Single Generator
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>19D629 </TD><TD>A/C Compressor</TD></TR><TR vAlign=top><TD>2 </TD><TD>19A216 </TD><TD>Idler Pulley (Without A/C)</TD></TR><TR vAlign=top><TD>3 </TD><TD>19A216 </TD><TD>Belt Idler Pulley</TD></TR><TR vAlign=top><TD>4 </TD><TD>10300 </TD><TD>Generator</TD></TR><TR vAlign=top><TD>5 </TD><TD>3D673 </TD><TD>Power Steering Pump Pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>8A528 </TD><TD>Water Pump Pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>6312 </TD><TD>Crankshaft Pulley</TD></TR><TR vAlign=top><TD>8 </TD><TD>6B209 </TD><TD>Drive Belt Tensioner</TD></TR></TBODY></TABLE>
Accessory Drive —7.3L Diesel Engine Dual Generator
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>19D629 </TD><TD>A/C Compressor</TD></TR><TR vAlign=top><TD>2 </TD><TD>19A216 </TD><TD>Belt Idler Pulley</TD></TR><TR vAlign=top><TD>3 </TD><TD>10300 </TD><TD>Generator</TD></TR><TR vAlign=top><TD>4 </TD><TD>3D673 </TD><TD>Power Steering Pump Pulley</TD></TR><TR vAlign=top><TD>5 </TD><TD>8A528 </TD><TD>Water Pump Pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>6312 </TD><TD>Crankshaft Pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>6B209 </TD><TD>Drive Belt Tensioner</TD></TR></TBODY></TABLE>
Accessory Drive — 6.0L Diesel Engine Single Generator
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>19D784 </TD><TD>A/C clutch pulley</TD></TR><TR vAlign=top><TD>2 </TD><TD>19A216 </TD><TD>Idler pulley (without A/C)</TD></TR><TR vAlign=top><TD>3 </TD><TD>19A216 </TD><TD>Belt idler pulley</TD></TR><TR vAlign=top><TD>4 </TD><TD>10344 </TD><TD>Generator pulley</TD></TR><TR vAlign=top><TD>5 </TD><TD>3A733 </TD><TD>Power steering pump pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>8A528 </TD><TD>Water pump pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>6312 </TD><TD>Crankshaft pulley</TD></TR><TR vAlign=top><TD>8 </TD><TD>6B209 </TD><TD>Drive belt tensioner</TD></TR></TBODY></TABLE>
Accessory Drive — 6.0L Diesel Engine Dual Generator
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>19D784 </TD><TD>A/C clutch pulley</TD></TR><TR vAlign=top><TD>2 </TD><TD>19A216 </TD><TD>Idler pulley (without A/C)</TD></TR><TR vAlign=top><TD>3 </TD><TD>19A216 </TD><TD>Belt idler pulley</TD></TR><TR vAlign=top><TD>4 </TD><TD>10344 </TD><TD>Generator pulley</TD></TR><TR vAlign=top><TD>5 </TD><TD>3D673 </TD><TD>Power steering pump pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>8A528 </TD><TD>Water pump pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>6312 </TD><TD>Crankshaft pulley</TD></TR><TR vAlign=top><TD>8 </TD><TD>6B209 </TD><TD>Drive belt tensioner</TD></TR></TBODY></TABLE>
Accessory Drive — 5.4L, 6.8L without A/C
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>8678 </TD><TD>Belt idler pulley</TD></TR><TR vAlign=top><TD>2 </TD><TD>10344 </TD><TD>Generator pulley</TD></TR><TR vAlign=top><TD>3 </TD><TD>3A733 </TD><TD>Power steering pump pulley</TD></TR><TR vAlign=top><TD>4 </TD><TD>8509 </TD><TD>Water pump pulley</TD></TR><TR vAlign=top><TD>5 </TD><TD>6312 </TD><TD>Crankshaft pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>6B209 </TD><TD>Drive belt tensioner pulley</TD></TR></TBODY></TABLE>
Accessory Drive — 5.4L, 6.8L with A/C
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>8678 </TD><TD>Belt idler pulley</TD></TR><TR vAlign=top><TD>2 </TD><TD>6312 </TD><TD>Crankshaft pulley</TD></TR><TR vAlign=top><TD>3 </TD><TD>10344 </TD><TD>Generator pulley</TD></TR><TR vAlign=top><TD>4 </TD><TD>3A733 </TD><TD>Power steering pump pulley</TD></TR><TR vAlign=top><TD>5 </TD><TD>8509 </TD><TD>Water pump pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>6B209 </TD><TD>Drive belt tensioner pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>19D784 </TD><TD>A/C clutch pulley</TD></TR></TBODY></TABLE>
That should cover the bases.
Stewart
Old Oct 19, 2007 | 09:04 PM
Greywolf's Avatar
Greywolf
Well...
YES, I suppose that works too
"Sire, we should explore a technology - call it overkill - which renders to all of our citizens far more than they require..."
-Civilization 2 game, Economic Advisor
Old Oct 19, 2007 | 09:23 PM
Stewart_H's Avatar
Stewart_H
Well...
Well, here's how my line of thinking went (uh oh... lol)
First, when I was composing my response, I only provided the routing for the 7.3L PSD. Then I figured since ZBeeble has a 6.0L, and he also posted in this thread, I better also include the routing diagram for the 6.0L PSD's.
THEN I figured someone with a 6.8L gasser would post up eventually (today, tomorrow, next month, next year after digging up an old thread, etc) and ask if I could provide the routing for their gasser.
So I used a shotgun to kill a fly. All in one post.
Stewart
Old Oct 19, 2007 | 09:26 PM
Greywolf's Avatar
Greywolf
Good on you - and WELL DONE!
Old Oct 19, 2007 | 11:57 PM
2manykids's Avatar
2manykids
Stewart
understand
Old Oct 20, 2007 | 12:25 AM
Stewart_H's Avatar
Stewart_H
Thanks for the rep points!
Stewart
Old Oct 20, 2007 | 02:49 PM
7.3 4X4's Avatar
7.3 4X4
If a parts guy looks at you funny when you ask about an upper radiator hose that doesn't run through the belt, just tell him you need a hose for an engine with dual alternators!
