I apologize for the parallax error this pic, I had a hard time holding the tape measure and taking the pics. But the end of the tape measure is in the shoulder of the centerlink as outlined in the instruction sheet
Again, I apologize for the angled pic, but the measurement was at the correct distance so I did not need to move the centerlink bracket
Reason: correct typos
Now, I am going to skip the pics of removing the old stabilizer. I am going to point out the difference between the two, and the reason why I started this thread. The new Bilstein has a stud on the Bracket end of the stabilizer while the stock does not. I called Bilstein to inquire about this and I was told that this is the correct part and the stud is there to keep the stabilizer in-line. The bracket side of the stabilizer sits forward compared to the clevis end of the stabilizer, so the stud helps keep both ends of the stabilizer in-line or parallel. The stud goes thru the bracket and it will bottom out on the shoulder of the stud so only the threads will protrude.
Notice the flats on the stud shank, this is where you hold the stud with 19mm or 3/4" wrench while tightening the nut
Here is a pic of the wrench on the flats of the stud shank
Reason: added text
Nice. I read MONSTER-4's thread first, he did a great job on his write up. I was just puzzled with the "stud end" of the stabilizer, so I made my own thread to address that issue. https://www.ford-trucks.com/forums/1...installed.html
Nice... Did you notice a difference on the way it steered or handles? I'm considering this for my next upgrade, then new front shocks. I don't like the way my EX steers, it seems to have a lot of play.
I have already adjusted the nut on the steering, I may need to go a little more, but with 200k+ miles on it, I'm sure its time.
Sounds like its time for a "Red Head" steering box, I put one on my wife's 05 this spring, what a differance it made, truck had less than a 100'xxx miles on it!
Yes it did make a big improvement, my old one was shot. When I tried to move the old one by hand, once it was off the truck, it only moved in "jerky" motions, it was not smooth movements. The Bilstein was worth the money.
I agree.
Glad to hear, looking forward to doing mine this morning after the frost thaws
Just priced the Redhead.... I think a real one would do the same job plus some. JK
I'm going to go with the steering stabilizer 1st, and then front shocks that need replacing. I'll decide then if a new box is needed. I appreciate all the info!!
I have Bilstein shocks and a Bilstein steering stabilizer on my '03 diesel Excursion.
Previously, I had a Rancho steering stabilizer (Bilstein did not have one yet to choose from). The Rancho was OK, but is not the same quality and stiffness as a Bilstein.
What a steering stabilizer does is reduce the wobbles and the "shocks" one may feel through the steering wheel.
It is stiffer and better made - great mod to have.
