How to replace door lock cylinders in the dumbest way possible
Old Dec 21, 2019 | 12:40 PM
FordTruckNoob's Avatar
FordTruckNoob
So the ignition lock cylinder in my truck has worn to the point where I can turn it on the first attempt maybe one in ten times. rather than replace only that and have to carry 2 different keys, I decided to replace all the lock cylinders on the truck.
This set This set
is one of the few I have found that has enough locks to replace the ignition, doors and tailgate locks. Time to get to work.
Phase 1: Remove the door card
Step 1a: Pop the quarter light trim piece off.
Step 1b: Pop the switch panel off
Step 1c: Pop the courtesy light cover off
Step 1d: Remove the two bolts. 7mm socket required.
Step 1e: Lift door card up and away from the door a little, unlock courtesy light from door card and set door card aside.
Old Dec 21, 2019 | 12:47 PM
FordTruckNoob
Phase 2: Remove obstructions to removing the lock cylinder. I opted to replace the lock without removing the handle from the door. This was because the thought of snapping open a 20-yo plastic clasp in 20 degree weather to release the latch operating rod did not sit well with me.
Step 2a: Remove bottom corner panel clips and peel door liner back.
Step 2b: Release the lock operating rod. Snap ring spreading pliers are ideal for this.
Step 2c: Remove latch mechanism screws. This is to allow the latch operating rod to move far away enough to allow the lock cylinder to slide out.
Old Dec 21, 2019 | 12:55 PM
FordTruckNoob
Phase 3: R&R the lock cylinder
Step 3a: Remove lock cylinder retaining spring clip. You will come to loathe this spring clip greatly.
Step 3b: Slide old lock cylinder out.
Step 3c: Use silicone grease to "glue" the new rubber seal in place in the cavity.
Step 3d: Using the new lock cylinder, reassemble everything in reverse order of disassembly. Enjoy your easier turning new locks.
Old Dec 21, 2019 | 02:01 PM
AllaboutMPG's Avatar
AllaboutMPG
Thanks for doing a nice write up with pics (cartoons always help)
So were all of your locks worn out or just the ignition?
Old Dec 21, 2019 | 02:08 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Another great write-up, thanks Leonard! I have added this to the 7.3L PSD Tech Folder where several more of your write-ups reside for the rest of eternity.
Old Dec 21, 2019 | 02:19 PM
AllaboutMPG
Not sure what all the locks cost you (the link you posted goes to a single ignition cylinder) but as an alternate method you could probably take your ignition cylinder out and have a lock smith replace the wafers for $20 to $30. Then you get to keep your old keys.
If you have sticky locks then this stuff is the bomb
https://www.google.com/search?rlz=1C...UQvARkQ4dUDCAs
Unlike wd40 and other sprays it leaves no residue for dirt to cling to. A shot in your locks once a year keeps them working smoothly for a long time.
Old Dec 21, 2019 | 02:56 PM
FordTruckNoob
Phase 4: Take door card back off to retrieve worklight that I left inside the door.
It was just the ignition lock that was worn. I wish I had known about the locksmith replacing the wafers option. The entire set cost me just over $100. I will correct the link in the first post to point to the right item. Thanks for the info on the lock lube. Maybe I won't have to replace locks ever again if I use this stuff.
Lol thanks.
Old Dec 21, 2019 | 04:44 PM
kbeefy's Avatar
kbeefy
Locksmith will rekey your new lock cylinder to match your existing keys for $25-50
DEMIGOD
Dec 19, 2023 02:23 PM
Glowplugger
Apr 9, 2016 07:24 PM
Sir.Dino
Nov 7, 2014 06:58 PM
syjl
Jun 10, 2014 05:30 PM
beer boy
Apr 14, 2008 12:03 PM
