Mile Marker hub install
Old Mar 10, 2013 | 07:28 PM
High Intentions's Avatar
High Intentions
Mod Specialist ;)
Just Got Mile Marker manual hubs this week and installed the today. This was one of the easiest mod's I have done.
First remove the center cap.
Then remove the snap ring that holds the factory hub on.
Next pull the factory hub out. Mine came out pretty easy. Some you may have to help out.
Then remove the 2 screws that hold outside hub housing on and sit it aside.
Install the Mile Marker hub into the axle. You'll have to wiggle some to get the splines to line up.
Push it in as far as it will go. Then install the retaining ring. Put in the open end first.
And finally reinstall outside hub housing.
The total job took about a half an hour. That includes set up and clean up. If you have the vaccum line still you should cap them off so you won't have a vaccum leak.
Old Mar 10, 2013 | 08:26 PM
EXv10's Avatar
EXv10
Thanks for the demo. Did you not like the stock ones?
Old Mar 10, 2013 | 08:34 PM
High Intentions
Mod Specialist ;)
Was having issues with the auto locking not locking and couldn't lock them in manually. The Mile markers was only were $130 and factory hubs are close to $400
Old Mar 10, 2013 | 08:35 PM
Oldtrucknut7077's Avatar
Oldtrucknut7077
Excellent! Thanks Eric.
Old Mar 10, 2013 | 09:16 PM
Archion's Avatar
Archion
Veteran: Marine Corps
And no creeper necessary... Looks good. Good to know for when mine give out. Finally got mine to turn, they had so much dirt in them... I dont think the PO ever turned them.
Old Nov 19, 2014 | 11:08 AM
Stewart_H's Avatar
Stewart_H
Bumping this up so I can find it easier later tonight so I can add it to the tech folder.
Stewart
Old Nov 19, 2014 | 11:45 AM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Originally Posted by Stewart_H
Bumping this up so I can find it easier later tonight so I can add it to the tech folder. Stewart
A year and a half late there bud, lol. I know your mod responsibilities aren't THAT occupying of your time. Sheeeeesh.
Old Nov 19, 2014 | 02:59 PM
Stewart_H's Avatar
Stewart_H
Correct. But you obviously assume I read every single thread in the forum.
Stewart
Old Nov 19, 2014 | 05:52 PM
High Intentions
Mod Specialist ;)
Cool thanks Stewart
Old Nov 19, 2014 | 10:44 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by High Intentions
Cool thanks Stewart
No prob. Made me realize I needed to do some reorganizing of the folder.
Stewart
Old Nov 19, 2014 | 10:49 PM
Stewart_H's Avatar
Stewart_H
All ribbing and kidding aside, if anyone see's a thread like this and you think it warrants inclusion in the tech folder, please send me a PM and give me a heads up.
Stewart
Old Nov 19, 2014 | 11:51 PM
Bently_Coop's Avatar
Bently_Coop
Eric- Where did you purchase the hubs at? They look sharp and since the auto function on mine doesn't work it would almost be worth while.
Old Nov 20, 2014 | 08:55 PM
High Intentions
Mod Specialist ;)
Bently I got them off ebay.
Old Nov 20, 2014 | 09:31 PM
Vince79vette's Avatar
Vince79vette
I too just got mine on ebay 150 shipped
Old Nov 20, 2014 | 09:36 PM
Bently_Coop
Thanks guys, will check it out.
