Steering Gear Box Adjustment
Old Dec 23, 2010 | 02:44 PM
texasjack's Avatar
texasjack
I assume the play in my steering wheel is in the steering box, anyone know how to adjust out the play? Already replaced tie rod. thanks!!
Last edited by Y2KW57; Jul 30, 2023 at 12:09 PM. Reason: Changed title from a question to a declaration, based on solutions shown in thread, which is now in FAQ.
Old Dec 23, 2010 | 02:47 PM
SLUF681's Avatar
SLUF681
You need to get someone to turn the wheel while you watch the shaft itself and see whether or not the shaft itself moves left and right. Could be the bushing worn out. Happened to me on my 97 Chevy.
Old Dec 23, 2010 | 02:50 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
There's a stud on top of the box with a locking hex nut on it. Loosen the hex nut and using an allen key on an extension, rotate the stud clockwise to tighten the gear lash and CCW to loosen. Be careful and go in small increments. Too much and you can lock up the gears and put the steering in a bind.
Old Dec 23, 2010 | 03:04 PM
izzybird's Avatar
izzybird
To add to Texas Outlaws post, make sure your wheels are straight and it helps to get the tires off the ground. You should make darn sure the slop isn't somewhere else before you do this. You can ruin a steering box pretty quick.
Old Dec 23, 2010 | 03:51 PM
Ziggy.'s Avatar
Ziggy.
Also check the nut that holds the pitman arm on the tapered shaft, I know Scott had a thread not too long ago about his loosening up since there was no lock washer on it. I had this happen on mine where the previous owner had a 4'' lift installed and the drop arm was not tightened to spec, when I got the truck I got maybe another full turn and a half out of the nut and took most of my play out.
Old Dec 23, 2010 | 03:59 PM
bulla's Avatar
bulla
I have adjusted mine and had good luck with it so far. Another post mentioned that coming out of a turn the wheel should straighten back up on its own. If it does'nt loosen it up till it does. I think this would require proper aligning for this to be achived. If it's overtightened it could lock up or cause the gear box to wear out prematurley.
Old Dec 23, 2010 | 05:01 PM
Stewart_H's Avatar
Stewart_H
Locate the allen bolt and locknut on top of the steering box. It’s close to the radiator. The locknut should be a 5/8".
Mark the allen bolt so you’re oriented and know where the starting point is, then loosen the locknut. Turn the allen bolt clockwise a quarter turn to tighten the gear mesh. Tighten the locknut and road test your vehicle.
Be careful not to over-tighten the allen bolt. If you do, the steering may become too tight and get extremely stiff during a tight turn, possibly causing you to drive off the roadway.
Keep repeating the sequence, turning the allen bolt a ¼ turn at a time, followed by a test drive, until you're satisfied with the performance. If you over-tighten the allen bolt, turn the allen bolt back a quarter turn, counter-clockwise.
There is a risk of over tightening the box and causing it to wear out prematurely, so I suggest you tighten it to the point where the slop is gone, and no further.
Most people will turn the allen bolt three-quarters of a rotation to one and one half rotations before they’re happy with the results.
Stewart
Old Dec 23, 2010 | 05:06 PM
bulla's Avatar
bulla
Thanks Stewart. It was partly your post that got my steering much nicer!!
Old Dec 23, 2010 | 05:49 PM
Bigcat350's Avatar
Bigcat350
I have helped 3 trucks using the same procedure that Stewart posted. But one of my friends needed a new steering gear box. The Red Head worked great.
Old Dec 23, 2010 | 06:03 PM
jeronlines's Avatar
jeronlines
I, too, used it to get what I needed AFTER checking all the steering and suspension parts for wear and play. If you don't you risk treating a symptom and not the actual illness.
Old Dec 24, 2010 | 05:55 PM
texasjack's Avatar
texasjack
Thanks guys for the infor.I'll take the adjustments slowly and a little at a time!
Old Jan 11, 2011 | 05:09 PM
cldomson1's Avatar
cldomson1
Anyone had pics of this box? I assume it's the hexagon shaped one at the end of the steering rod.
C
Old Jan 14, 2011 | 12:56 PM
cldomson1's Avatar
cldomson1
Is it #6 in this pic:
http://www.trademotion.com/schematic...al/T140085.gif
Old Apr 3, 2015 | 12:07 PM
Lex2002's Avatar
Lex2002
So this procedure could help the constant course correction I need to make on my 7.3 with 202k miles?
I have new Michelin tires, recent alignment, new ball joints, and all new steering linkage. And still...back and forth and back and forth goes the steering wheel as I drive down the highway.
The steering dampener is also relatively new. Maybe 40k miles....
Old Apr 5, 2015 | 09:07 PM
Stewart_H's Avatar
Stewart_H
Yes, it could help.
Stewart
