2005+ Style F-250 Grab Handle Installed in 2002 X
Stewart basically dared me to do this...so
Remove the drivers A Pillar trim and you'll find this. Note the area in the pinch seam where there are convenient places to put 4 bolts
Drilled 4 holes in the pinch seam. Then used the OEM grab handle bolts (I had them lying around from my F-250...and the handle). Drilled the hole just a bit under size, and used the bolt itself to tap the threads.
Took the trim inside, used crayon to mark the cutout area and made the recesses.
Back out to the truck and lined up everything. It bolted right up
Put it all together. That's it for tonight. I'm going to pull the handle off tomorrow and do a bit more trimming so it'll fit a bit more flush. very happy with this little mod. now to find some color matching tan paint...or a 2005+ Drivers A pillar trim piece in tan
Here is a side by side of the 2002 vs 2005 style
The drivers side will work 100% from a 2005-2007 truck
the passenger side grab handle is smaller. see the pictures above where I show the 2 together. I don't remember what the passenger A pillar looks like under the trim piece...so a 2005 style handle on the passenger side may not work without custom drilling some holes.
but if you have the 2005 trim piece, it'd be easy to just install that piece and use it to locate and drill the holes needed
