Transmission Cooler Flow Test
Old Jun 19, 2017 | 07:09 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's probably worthwhile to run a cooler flow test.
Warm the trans up. It should be at least 150°F.
Have two containers, each at least one gallon.
Get a hose that will fit over the cooler return line at the rear of the trans.
Remove the return line where it enters the rear of the trans.
Put the hose on the return line and put it into container #1.
Have a helper start the engine and leave it in park and at idle.
When the flow is steady out of the hose (that should only take a few seconds) move the hose to container #2 for EXACTLY 15 seconds, then put it back in container #1.
Shut the engine off.
Results:
If fluid sprayed out of the transmission, the test fails. A small dribble is fine, but spraying is not.
If there is less than a quart in container #2 the test fails.
If the test fails either the cooler bypass valve is stuck open or there is a restriction in the cooler circuit.
Old Jun 19, 2017 | 01:51 PM
Stewart_H's Avatar
Stewart_H
The above post was copied from a trans thread in the Excursion forum to it's own thread for purposes of linking to the Excursion forum tech folder. That's why it's here and not in the transmission forum.
Stewart
Big_Red99
Aug 7, 2019 02:08 PM
Diamnd1
Sep 7, 2017 07:34 AM
SoCalAngler
Sep 8, 2014 11:26 PM
petermawn
13
Jan 11, 2012 05:48 PM
monte97z
15
Dec 31, 2011 02:26 PM
