Injector Buzz Test - General Question
Old Feb 19, 2020 | 06:07 PM
KelVarnson's Avatar
KelVarnson
The other day I was helping a friend with a '96 OBS do a little troubleshooting. We used Forscan on my PC to do an injector buzz test. During that process we disconnected two injectors.
I was under the impression that what you are supposed to hear is all of the injectors buzzing together at first, then each of the eight injectors buzzing individually. However, with the two injectors disconnected, we still heard eight distinct buzzes (after the initial group buzz).
So what else is buzzing?
Old Feb 19, 2020 | 06:20 PM
Wes444's Avatar
Wes444
Someone else recently mentioned the same thing in a thread. The other injectors still buzz, although very faintly. We just usually can't tell from inside the cab
Old Feb 19, 2020 | 06:37 PM
KelVarnson's Avatar
KelVarnson
Huh... Doesn't seem like it would be nearly as useful of a test, if they all buzz at once.
Old Feb 20, 2020 | 06:07 AM
MoBill122's Avatar
MoBill122
Papa Smurf
Thinking back... and my memory is terrible.... but was thinking it buzzed each injector, then the last was all eight at once. And do it when the engine is cold, like first thing in the morning before you crank it.
Old Feb 20, 2020 | 08:00 AM
SkySkiJason's Avatar
SkySkiJason
Buzz test rings all (8), then 1,2,3, etc.
With injectors unplugged, or with bad solenoids or wiring issues, you can get a ‘ghost buzz’ on all (8).
Old Feb 20, 2020 | 02:37 PM
KelVarnson's Avatar
KelVarnson
Maybe it depends on the software? I used Forscan, and for sure it did all eight and then each individually.
I did, but just out of curiosity, is there some harm in buzzing warm injectors? Or are you saying that it is just a better troubleshooting tool if it is cold?
Even with (hypothetically) all eight unplugged? That is the basis of my question, is there anything else (e.g. a relay) that buzzes during the test? I am assuming that the injector drivers are solid state, even in the older trucks. Seems like they would have to be. But with two of the injectors disconnected, we still heard eight buzzes, and they all seemed like the same volume. My ear may not be as well-trained for this...
Old Feb 20, 2020 | 02:44 PM
SkySkiJason
With one or two injectors unplugged, you can hear a buzz when it’s time for those to buzz - but the noise will come from the other injectors.
You should have gotten P127x ‘high to low side open’ or similar DTC with injectors unplugged.
Old Feb 20, 2020 | 04:23 PM
Bobcatbob's Avatar
Bobcatbob
Are we saying the sound we hear during the individual buzz portion does not indicate health of the injector, specific to armature clearance.
People say to listen to each buzz sound difference.
Now, what does that sound difference indicate?
Sorry, I'm just a little confused now, as I was using the sound to isolate a tight armature on an individual injector.
Old Feb 20, 2020 | 04:47 PM
KelVarnson's Avatar
KelVarnson
Thanks very much for clarifying that.
Kind of surprised this is how it works. It seems like it would be so much more useful if it buzzed each injector completely individually.
Indeed we did.
Old Feb 20, 2020 | 05:10 PM
SkySkiJason
It does. Unless there is a open line or a short to ground. In those instances it’s possible to hear a ‘ghost buzz’ on other injectors.
Old Oct 25, 2020 | 11:03 AM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
eatont9999
May 8, 2012 09:20 AM
BigfootIDI
Apr 10, 2010 03:19 AM
throwdown
20
Feb 19, 2010 07:12 AM
jenmarent
Mar 25, 2006 02:31 PM
