7.3L PSD Tech Folder Content Repository
Old Jul 29, 2019 | 12:03 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
This thread is locked and only serves as a source to store and archive information contained in the 7.3L PSD Tech Folder located at the link below. If any of the information in this thread has been mis-linked or the creator has been misidentified, please let me know via PM and I will make changes to reflect the correct information.
https://www.ford-trucks.com/forums/1...-7-3l-psd.html
Old Jul 29, 2019 | 12:06 PM
Sous's Avatar
Sous
FTE Emeritus
Door cable repair posted by Bill De.
File Type: pdf
Old Jul 29, 2019 | 12:15 PM
Sous's Avatar
Sous
FTE Emeritus
Injector Break Out Box posted by Fat Diesel.
File Type: pdf
Old Jul 29, 2019 | 12:42 PM
Sous's Avatar
Sous
FTE Emeritus
4R100 Tech and Rebuild Data posted by z31freakify.
https://redirect.viglink.com/?format...lAoiX_7A8uhEXw
Old Jul 29, 2019 | 02:39 PM
Sous's Avatar
Sous
FTE Emeritus
Images posted by Wesley Green and Tugly.
Old Jul 29, 2019 | 03:12 PM
Sous's Avatar
Sous
FTE Emeritus
Did You Know posted by Brian42.
File Type: pdf
Old Jul 29, 2019 | 03:52 PM
Sous's Avatar
Sous
FTE Emeritus
1999.5 update list posted by Cookie88.
File Type: pdf
Old Jul 29, 2019 | 03:55 PM
Sous's Avatar
Sous
FTE Emeritus
GTP38 Turbocharger guide posted by Cookie88.
File Type: pdf
Old Jul 30, 2019 | 08:53 AM
Sous's Avatar
Sous
FTE Emeritus
Lifting cab guide posted by KubotaOrange76.
File Type: doc
Old Jul 31, 2019 | 03:55 PM
Sous's Avatar
Sous
FTE Emeritus
PSD diagnosis on the cheap posted by scoutcamper.
Old Aug 1, 2019 | 02:16 PM
Sous's Avatar
Sous
FTE Emeritus
Steering box adjustment posted by wpnaes.
File Type: pdf
Old Aug 1, 2019 | 02:31 PM
Sous's Avatar
Sous
FTE Emeritus
Wheel, Tire, Bolt Pattern, Lug Nut information posted by jklnhyd.
Old Aug 2, 2019 | 09:19 AM
Sous's Avatar
Sous
FTE Emeritus
IDM wire map posted by FordTruckNoob.
Old Aug 2, 2019 | 03:10 PM
Sous's Avatar
Sous
FTE Emeritus
Quick reference guide posted by Whitetmw.
File Type: pdf
Old Aug 3, 2019 | 09:19 AM
Sous's Avatar
Sous
FTE Emeritus
Images posted by aawlberninf350.
