- **$75 Clutch AND Flywheel Combination***
- Please help dont know what to do!
- failed inspection
- Wet Weather
- 1982 valve tap and vacuum leak
- Bad intake gasket
- Running to rich!
- Manifold migraine
- carb. icing
- carb rebuild...
- swapping an '85 to an '88
- What kind of oil does every one use?
- Tranny Codes
- cross-flow check valve recall
- spring brain teaser!
- bell housing bolt pattern
- CFM of throttle body
- 300 crank question:
- function of a throttle body
- carb intake on EFI head?
- I-6 Rebuild ?'s
- heat riser tube
- Lifter Clack
- spark plugs shorting out
- converting an efi to carb.
- Code 24
- Shorter starter for headers
- timing issues
- Rough Idle or bent rod?
- What's the difference?
