- help me lift this motor!
- 88 300 6 fuel pressure
- Will a 75 intake/exhaust manifold work on a 69 300 6 cyclinder?
- two (possibly dumb) questions
- Installing Hedman Headers, What about EGR Valve?
- four miles to the gallon isn't so great
- NEW FLYWHEEL CLUTCH COMBOS on E-Bay CHEAP!!!
- Overheating
- 4.9 headers
- Looking for pics for the 300 I6
- 4 barrel
- does this trouble code or how the engine light acts sound familiar?
- Ford needs new Inline!!
- 300 puffing blue smoke....
- Spout disconnected.....how should it idle ??
- Is the 4.9 Liter a.k.a. the 300
- swap in a 460...
- Codes 67 and 82
- Distributor not turning
- Coolant Leak...
- bigger injectors for I-6?
- Plugs, wires, cap, rotor, fuel filter
- EGR Valve
- Fuel Filter
- Beefier Transmission for the 300 I6 2wd
- Boiling in heads
- string of bad luck
- vacuum question
- cruise out and airbag light
- How can I go before an injector swap is mandatory?
