- Engine dies at idle unless in gear
- Spring spacer?
- leaving air-idle control valve unplugged?
- Ring gear question?????
- Going to add stop leak
- Air charge temp. sensor
- Intake broke tap in bolt hole, argh.
- Mpg
- performance/economy carb?
- weak spark
- 1982 300 ci vacuum diagrams
- engine turns over but will not start
- RPM problem
- 300CI inline 6cyl won't stay running
- Torque on cylinder head
- 300 I6 dumping fuel
- straight 6 and C4 match up
- Does the HD truck engine have?
- How much will chevy 1.75 rocker arms do?
- How common is ?
- Fresh rebuilt 4.9 300 inliner w/no oil pressure!
- turbo head ?
- How to hold crankshaft while installing harmonic balancer bolt?
- Does anybody want rebuild specs?
- Tightening A/C Belt
- Questions about connecting rods
- New pics of the 300 rebuild progress
- 82 f100 4.9l 300 i6 very rough idle
- Waterpump
- Common Causes, CEL 420 Code
