- Got a swap in mind.
- 84 300 timing
- Replaced timing gears and wow!!!
- Replacing Head Gasket/torqueing head bolts/replacing rings, etc.
- Power UPgrading and EFI I-6
- My i6 won't stop missing
- Auto shop reaction to a 300
- modifyed stock intake (2 1bbls?)
- hydraulic clutch
- Oil Pressure
- 95 F150 I-6 "Sputters"
- Wont go above 55 without choking.
- Smog Pump Removal = MOre Power?
- more hp inline 300
- 78 f100 running hot
- Air/fuel Ratio
- 4.9 lower end knock
- Chain hoist attachment location big 6
- Will The 4.9 Slide out with the Condensor in?
- Will it hurt my truck to run straight manifolds?
- Oil Pan
- slightly sideways??
- 1993 F150 Spark knock..
- Secondary air injection systems
- cold air intake
- Valves Pinging, Need Advice
- Exhaust...from the header back.
- Batteries draining down
- clifford 4 bbl intake
- wal mart Batterys
