- need help with plate on block
- Crank timing gear
- 1985 300 Rpm
- Good sounding exhuast
- no compression
- 223 and a 3 speed
- Carb Change
- 223 vs 300
- 5.8 Throttle Body
- flowmaster/exhaust problem
- pics 78 f150 300I6
- Best Gasket for Clifford/EFI Manifolds
- PCV Valve question
- Now were making power!! Couple more??'s
- what's the lightest flywheel??
- Anyone know what size screws are in a Carter YF Carb?
- Carb, Manifold, Distributor swapout
- walker down pipe
- Running Rough, tried all we know
- Timing gear weight differential
- Transmission options
- Cyl head ID ?
- Only starts on starting fluid...
- Need 300I6 pushrod guide plates
- Testing Fuel Gauge
- harmonic balancer
- starter questions
- tool for fuel filter removal???
- need help with new carb
- My new truck
