- oil pressure
- Carb to EFI
- noisy valves under load
- 4.9L i6 mods?
- 300 I-6 for 1980 F-100
- replace 4.9 6 cyl. with 351 or 460 v8
- Clogged catalytic converter??
- Warped manifolds
- Mileage Records???
- Exhaust gas coming from the air pump
- YFA F/B 1bbl Mixture Adjustment
- 300 I6 Combustion Chamber
- How do i find what gear ratio i have?
- Need some straight advise
- Starting Problem
- Seeking 300I head porting advice
- Old Log to New Split Manifold?
- Quarts of oil??
- Dual Cats
- Tires and gears
- 4.9 overbored?
- header selection
- Timing chain broke??
- header/intake/carb swap
- 215 six
- carb problems?
- Ignition timing 10* BTDC
- Would really appreciate any help!
- 92 4.9 Headache
- flywheel replacement
