- Front Seal Oil Leak on 240
- '93 shortbed - you're opinions on best P.M.?
- will I see any results with a 4bbl. carb....
- carbs
- fast 300
- Tranny swap
- 1978 Carter YF 1bbl....choke
- 84 6 cyl timing problem
- Fan Clutch
- 95 F-150 questions
- Exhaust Leak
- Finally did a little experimentation on rpm max......
- Rearend ring size
- Big Tires and Axle Ratio's
- Cluster Tach change from 6K to diesel 4K
- Initial ignition timing
- Gas mileage, O2 sensors and more... OH MY!
- Stacks on a 300?
- oil filter attachment?
- Ignition nightmare on '84 F-150/4.9L
- Slight Vibration
- what are you getting for mileage?
- High Flow catalytics that fit?
- Temp guage not working right....
- LOOKING FOR EDDIE
- Rear Axle Gears
- Instrument cluster change to tach cluster
- rough running after ex. mani change
- Carter 1v troubles???
- No load engine miss
