- Air Cleaner Broke
- Tips and Tricks
- efi head mods (porting and such)
- Taurus Fan Installation
- Which year efi ex manifolds work on what????
- manifolds to block studs and bolts
- Couple different problems with my '96 300 l6
- Ok I come back from V6 and V8 now.
- What is the purpose of this vacuum line (diagram included)
- What am I missing
- What goes where? Carter vac ports...
- Main Seal
- Bronco Saginaw P/S pump
- EFI exhaust manifold y-pipe
- help with part ID
- 6 Speed, Anyone?
- My semi-monthly plea
- Harmonic balancer
- Do these plugs look rite for mpg ?
- CAM SELECTION
- EFI Manifolds
- quick intake question
- Aluminum heads
- Broken Bolt ???
- Smog Pump Removed = Failed Inspection
- 95 Efi 300 motor /duraspark
- Graphite grease?
- Hard to start when warm
- 95 I6 motor should i get it ?
- Hard starting when cold
