- starter relay failure
- Timing & tuning carb w/ vac gauge questions
- Done a Offie & a Edelbrock change over also a D.S.P 2 changeover having a few problems??
- 4.9 lean almost all the time
- Need help
- Correct carb?
- big honkin muffler?
- Anyone going to Mac Tools US Nationals?
- Final build list.....Hopefully...
- Engine shake, low oil pressure
- "He" Lives!!!
- Looking for a EGR valve plate/spacer
- Weird Fuel Issue...
- Check engine light...HELP
- 4.5 miles per gal 300 i6 !!!
- york style A/C compressor on 300?
- 1980 300 plastic timing gear?
- More HEI disappointments
- Is my 300 worth saving?
- adding water temp, oil temp, oil pressure.
- egr and smog pump delete
- Forced induction???
- Vacuum hose for spark advance
- ignition- points to TFI-IV?
- Clifford's triple carb intake
- 4.9L Ford trivia...
- Cutting Plugs
- Possible 300 I6 supercharger setup-Planning Stage with 6Cyl Bill
- Performance help
- 4.9 96 F150 Missing/Bucking Help!!!
