- Question for 4x4's with 300 six's.
- low oil pressure
- What carbs are interchangable?
- im flooded
- What about racing an I-6 in a streetrod?
- '53 215ci piston oil ring question
- Better Gas Mileage
- Where to buy tranny/motor mounts at?
- Down from 5.8
- Head Gasket?
- Exhaust Question
- Carbed to EFI Conversion-Head Question
- Just a question.
- Valve cover removal
- Where is my ignition module located?
- What would you do?
- pulling codes, like pulling teeth?
- Smog Inspection
- EFI - What is the best for towing?
- gear question
- Timing Marks???
- Just passed the Sniffer
- EGR spacer
- 300 in a 72 F250...can it bolt up?
- Fuel Injector Question
- engine overhaule
- 250 Hp
- Overheated.....results??
- Tranny Fluid?
- building truck for trails
