- The need of carb spacers with an offy I6 intake
- Compression, duration, etc.
- New carb won't adjust
- 600cfm carb with 4bbl intake and good headers???
- Which radiator will work here???
- 300 I6 exhaust manifold
- Hesitation on acceleration
- Where is the thread about "how many RPM's are you running?"
- Slight miss at idle. Do they normally do this? (Long)
- can it be??
- 302,351
- Truck runs better
- Aftermarket (High performance) parts for 4.9L I-6
- Need a vacuum advance unit.
- Engine R&R
- Ok where is it?
- engine swap
- awesome sound
- weird noise in 300I-6
- OK....Reground stock cam....New lifters
- Looking for a 300 I-6 and manual tranny in Northern Cali
- 300 inline six....The best motor ever made!
- Speed Sensor
- Miss
- Transmission?
- Throttle Position Sensor
- 4 barrel Offy on E-bay
- Three On The Tree
- Inline 6 Choke Not Working (Thermostat Check Procedure)
- New fan clutch
