- what is this...?
- 1981 300 stock Carb/choke issues
- First time ford buyer 1989 full size bronco custom xlt converted to an inline 6 300 from a 302
- Howard's 263 cam (via Summit)
- pulling head w/studs?
- Clifford intake with two piece fuel injected motorcraft exhaust manifolds
- Lokar 48" cable & Offy C
- Camshaft Timing Gear Puller T82T-6256-A
- 302 to 300 Engine Swap
- Pinning Rocker Arm Studs
- Radiator hoses for 360 to 300 swap
- Off road lights
- Feedback carb to duraspark
- Need advice on camshaft
- 2 barrel carb vs. 1 barrel carb?
- Anything wrong with the comp cams lifters?
- overall gear ratio - '95 F150, 5 sp. manual?
- 84 F150 4.9L I6 300 new carb & intake?
- reverse pcv vacuum???
- 1995 E150 4.9 300 IL6
- 5/16-24 Locking Rocker Arm Nuts???
- engine goin in finally!!
- Clifford Performance Valve Cover
- converting carb to fuel injection
- V.advance setting?
- Phantom Aluminum Intake
- HELP! Need Knock Sensor for my 1988 4.9 six
- Pulling feedback carb
- clutch question
- Redhead S/box--group discount
