- 4.9 performance
- Putting a cam in questions?
- Step by Step Assembly guide for putting my 58 223 back together.
- engine rebuild advice?
- Rebuilding my 300 need opinions/ideas please
- I-6 1984 E-150 vrs '87 F-150 manual trans (3 speed with OD) any differences?
- Tips on modifying Ford 6 cylinder engines
- a serious ? stock factory heads only,
- Gotta love the attention an I6 generates!
- Another "no bottom end" thread, with a lot of codes...
- Full spec sheet for 300 engine wanted
- Screw in Rocker Arm Studs
- older mercury motor question! pics
- Super/turbo charging a 300 with factory MAF?
- Noob with '95 4.9L F-150 - oil cap question
- Do other heads fit on 300 I6?
- How much hp gain?
- Cam Swap should I change Rocker Arm Studs?
- My 300 Build - with PICS
- L.A. (mpg) dreaming
- Clutch trouble
- Has anyone actually used the HD exhaust manifold?
- 4 barrel intake=were dose kick down go
- 1953 215 rocker oil tube?
- 4.9 Con Rod and Crank clearances
- Doing project this weekend, need advice
- Anyone tried Powerjection?
- 300 HD intake and Clifford
- 300 and ZFS542 (I almost cried)
- 300 Fuel Econ tips
