- Belt Pattern
- What is needed to install 19# injectors on a 300-6 (EDDIE!)
- 300-6 oil sender locations
- 240 I6 and 3 speed price?
- Is my 4.9 RPM challenged?
- wind noise
- I have two questions?
- chip, cam, timing and gears?
- Engine Miss, Skip, Stumble
- Street modify?
- Other inline six sites?
- Header installation
- i-6 vacuum lines
- engine identity crisis
- Couple of Questions
- OFFENHAUSER intake vs. CLIFFORD
- Poor Performance
- Bouncing F150
- check engine light...
- carb icing
- Oil in air filter and housing
- if this happens one more time!!
- Rhythmic Vibration
- Pan gasket "squirting" out
- Broken bolt on exhaust outlet
- Which carb to go with upgrade???
- hesitation or dies
- fuel filter??
- Fuel Guage
- is there a comp. controlled 2 or 4bbl I can use?
