300 crank question:
Old Mar 25, 2004 | 07:41 PM
bremen242's Avatar
bremen242
Question 300 crank question:
When it gets nice(r) out, I'm going to pull my 300 and replace the crank, oilpump, main seals, and bearings. I am going to order a crank beforehand so I don't have to wait to get mine cut at the machine shop.
the question is: there are two cranks available for my year, one with an oil slinger by the rear main seal, and one without.
Anyone have a clue on this? the motor is in an '85 f-150 4x4...
Old Mar 26, 2004 | 06:40 PM
Silver Streak's Avatar
Silver Streak
Take this with a grain of salt because I'm just making a somewhat educated guess. One crank is probably for use with a one piece rear main seal and the other for a two piece. That is about the year they swithed to the one piece, and 85 might be a year that it could be either.
Old Mar 26, 2004 | 08:04 PM
bremen242's Avatar
bremen242
I looked on the parts website, and they said the cranks were interchangeable, which is really WEiRD.
btw, silver streak- I ran into a guy with an 88 motor he'll sell for $100 if I help pull it. Can I pull the EFI junk off and use it with the old carb&manifold?
(for the record, I'm going to pull all the EFI to eventually swap the truck entirely to EFI)
Old Mar 30, 2004 | 03:40 PM
The_Ryan_Lilly's Avatar
The_Ryan_Lilly
I think that the efi block will work with the carb head, carb, and intake.
Also 85 was a year that many things were changed, trucks made in late 85' have parts that corispond to 86' model year. As for the 2 cranks, Good luck.
Xclimation
Jul 22, 2011 10:54 AM
Redhorse719
Jan 6, 2011 09:56 AM
ram2miller
Nov 28, 2006 12:15 AM
