- 1988 F250 - 4.9 Wiring
- 1991 4.9L timing mark clarification
- Clifford Heads
- ticking
- Source for Carter YF Parts, idle screw in particular??
- How should I rebuild my inline six?
- 84-F250- 300 - 6cyl stalling
- Timing Mystery
- 262 six
- motor choice
- What gears are REALLY in my truck?
- Engine Block Number
- Oil pan Gasket replace question
- Must be rich, that's what I'm told?
- Inline 300 fuel injected converted to carb
- Point gap
- 300 won't idle when cold
- stalling 4.9
- 223....
- Anybody looking for EFI manifolds?
- '66 300 cid points gap, dwell angle...
- carburetor
- 300 is wore out take II, or . . .
- 300 Has Shaky Idle...
- 300 6 doesnt want to start
- '85 miles per tank
- Is my oil pressure too high? 23-25psi at idle and 40-50psi while cruising
- Cracks In Efi Exhaust
- put new rings in and couldn't crank the motor
- Towing with a 240?
