- Best Carb?
- '79 300 No Power (tuning question)
- 4.9 efi swap done have question
- E4OD swap
- site closed
- Looking for used 4 barrel maifold and 4 barrel carb
- Cold Idle issues
- EGR Question
- refresh me extra quart oil filter number
- very high idle - 3500rpm
- 95 e250 with 4.9l won't start after shutting off
- winter oil
- MSD/performance ignition?
- Distributer gear
- Dumb question about new water pump
- efi ex manifold
- A/C clutch does not cycle on/off?
- TPS Resistance Check Question
- Is it just me or.....
- A.I.R. Pump for forced air?
- offy intake swap?
- Should I swap the I-6, 300 to any Ford V8.
- 89 4.9 5 speed bucking/bogging around 2000-2500 rpm?
- 78 300 fuel pump
- Air Filter for '77 300
- Help need to locate cam sensor on a 95 ford f150 inline v6 4.9
- ford 4.1 [250] 6 cylinder harmonic balancers
- Does the EGR close with spring pressure or does it need vacuum?
- EGR
- What's this part of the choke do?
