- oil type and pressure
- What should water temp difference be...
- dual two barrel carbs
- Engine and Settings Help!
- Check this monster out!!!
- EFI or carbureted?
- Audio Tach
- Timing issue
- 1996 f-150 4.9 300
- FI 300 & 5 speed combo comments / opinions
- got my leaks fixed (i think)
- inline 300 6 cyl split manifold, no power
- 6 cyl swap
- Emmissions puzzle
- head flow data?
- 4.9 echast questionnnn
- gas cap
- adding two more cylinders to a 300-I6 = 408w? :)
- dizzy ?
- new to this forum
- Fuel Injected Guys- Which Fuel Pump Are You Using?
- Carter YFA difficulties
- Harte3
- Adapting desert cooler radiator--390 to 300 swap
- vac advance/timing question
- 1974 E-100,200 straight-6 vacuum lines
- How to change head gasket on 79 Ford 300?
- What brand carbs and size are you guys running?
- electric fan conversion--390 to HP 300
- codes
