- non-standard head gasket
- Windage tray
- Slugish
- flying 300
- 4.9 Exhaust
- Advice on a "freshening up"
- Water anybody?
- 1984 i6 black smoke???
- Looking for Air Cleaner Housing
- Where to get a 390 holley?
- 351W valve seals
- ECM Computer Ideas Needed
- high-pitched whistling noise above ~2000rpm
- Tube removed from 4.9 EFI... trouble?
- Either a Electrical or vacum problem. Could it be both?
- Spark Plug Gap?
- cutting carbs
- is the 240 in6 as good as the 300 as in reliablility
- bad oil leak
- 3.55 gears
- EGR stumble...... finally found the source and cure
- Parts
- best sounding exhaust/no emmisions tests??
- IAC problems
- Lifter change w/ head on?
- Fuel pump rebuild kit??
- Freshing up the 300
- Where am I going wrong?
- What year is my six ???
- Cam Bolt
