- upgrades
- Oil problem 94 F-150
- Newbie has question: 300 heads
- Secondary air injection manifold
- Transmission swap
- how would this sound?
- dual quad pics
- Submerged 300
- distributor shaft pin sheared...twice
- Oil Pump Replacement
- Aod Carb 300
- Does it really work ???
- Antifreeze
- 4.9 oil leak
- No oil pressure at startup
- Water pump??
- low end miss in 300
- Spare wire
- power question
- 84 f150 no pick up?
- Alternating Oil Pressures
- Internal oil leak???
- Alternator wiring
- Engine Problems- PLEASE HELP
- intake manifold c or dp?
- 223 Bent Push Rod
- Heads
- engine decoding
- Radiator flow question
- Dyno sheets for the stock 300
