Rough Idle or bent rod?
Old Mar 23, 2004 | 12:41 AM
Turbonium's Avatar
Turbonium
Hello,
I recently aquired a 74 F100 long bed (stepside) with a 240. The head gasket leaked and hydro locked #3 and #4 only (I think). When I attempted to start the motor the fan didn't even make a quarter turn, the engine didn't fire at all. After correctly torquing the head and clearing the water the engine started fine.
It has always had a rough idle, but I'm wondering if I could have bent a rod and made it worse? I'm hoping not as the engine still smooths out at higher rpm's. I'd think the vibration would get much worse with high rpm's with a bent rod.
Anyway I'm figuring if the bottom end is ok I'm just having some valve problems. I have no indication of actual mileage on the engine, but it runs like it needs work. What do you guys think about this price for a head? Ebay Auction
Thanks for reading my rambling post, I've had a long day wrenching and am maybe slightly delirious. I appreciate all the info in the forums and tia for any suggestions.
Old Apr 12, 2004 | 01:17 AM
Turbonium's Avatar
Turbonium
Well I pulled the head and replaced the gasket (new valve seals as well). The existing gasket was blown between #3 & #4. This was the culprit. The engine runs damn fine now and doesnt smoke to boot.
nomad221
Sep 20, 2014 06:15 PM
ford557SCJ
Modular V8 (4.6L, 5.4L)
Oct 3, 2013 05:36 AM
79F150400M
16
Jul 4, 2011 04:23 PM
CharlesFrankenstein
Jul 4, 2010 11:14 AM
