- Why do I have all the best luck?
- Looking to buy F150 w/ 300/5 spd need opinions
- Need help with a rebuild
- Where would a block heater plug into on a 300?
- Oil pans on my 300
- 1996 4.9 OBDII timing???
- to port or not to port
- Keith Black Pistons
- higway RPM
- Oil Leakage
- transmission and other questions
- what to tell the machine shop
- Distributor Vacuum ported? also whats average vacuum reading?
- 1989 ford f150
- Carb Flood / Stumped
- found a 240 head
- Missing PCV and hose...
- Stupid Emissions
- Clutch questions and opionion
- 75 F250 300 Power Problems - Electric Choke? Help!!
- Need help with this???
- fuel pump issue, 300cid
- what exuast is for me?
- Can you put a 2 barrel carb on a 86 300 6
- engine runs better with egr vac line removed and sensor unplugged
- Can you put a 2 barrel on on 300 6
- Egr Tube and Vacuum Line..
- '78 high amp alternator
- Time to rebuild
- lookin for a locker
