What's the difference?
Old Mar 22, 2004 | 10:44 PM
fast frank 66's Avatar
fast frank 66
what are the differences between the I-6 they put in trucks and the I-6 they use for generators and other industrial uses? is it possible to put and industrial motor into a truck? I can get a practically brand new industrial I-6.
The plate on the motor says
Type: B6PF-6005-A
Options: S0-31
what will it take to make it work in a truck?
Old Mar 24, 2004 | 09:14 PM
broncr's Avatar
broncr
The industrials (from what I've read) have a forged crank. It would be a stronger unit than the regular truck engine - which is saying a lot! Hold out & see if someone can verify that with the engine code.
Swapping on your accessories should be all it would take. I'm no expert - I'd advise waiting for futher opinions & input. However, if the price is right, you probably can't go wrong!
broncr
Old Mar 24, 2004 | 09:37 PM
dogdaysunrise's Avatar
dogdaysunrise
That would be a pretty wild swap, but i doubt it would work the way you would want it to
Old Mar 25, 2004 | 06:02 AM
Ford_Six's Avatar
Ford_Six
I believe the industrial engines are only rated for 90-something horsepower, with lower compression. IIRC, 78 or 79 was the last year for forged cranks too. I hate to direct you somewhere else, but you might want to try inliners.org.
Old Mar 25, 2004 | 10:31 PM
82F100SWB's Avatar
82F100SWB
Only difference in the later industrial engines is the lower 8:1 compression ratio, the oil pan, and possibly the exhaust manifold(no forged crank, ah well...) They are essentialy what came in 1986 F-Series equipped for leaded gas(they still sold 'em in Canada) Duraspark II, Carter YF(not YFA,) forged pistons, no EGR or AIR pump, rated at 124 HP @ 3600, 241 ft/lb @ 2000(same as a truck.)
Basicly, if your truck is carbed, bolt on your power steering brackets(alternator bracket is more desireable, stamped steel, no AIR pump bracket, and the alt. sits farther from the exhaust manifold) and truck engine mounts, flywheel, clutch and bellhousing, then send that puppy home.
Old Mar 25, 2004 | 11:44 PM
faroffthetrack's Avatar
faroffthetrack
dont truck i6's have a forged crank too?
Old Mar 26, 2004 | 12:32 AM
82F100SWB's Avatar
82F100SWB
Nope, only early HD's got a forged crank, everything else is Nodular cast iron.
Not to worry though, Nodular is plenty strong, it keeps us 460 guys happy(Ford never made a forged 460 crank) I had forged in my 300, just cuz I had it...
Old Mar 26, 2004 | 09:33 AM
oldhalftons's Avatar
oldhalftons
some industrial 300's have a different valve cover with a 2-3" tall tube welded to the top. the oil fill cap threads into this. this is so the engine can run for extended periods at a 10-15 degree side angle without oil seeping out of the fill cap.
Usually you see these in combines.
Old Mar 26, 2004 | 03:20 PM
faroffthetrack
yea i got that valve cover on mine
Old Mar 26, 2004 | 07:29 PM
82F100SWB's Avatar
82F100SWB
The EFI 300's use this valve cover, they extended the filler so you wouldn't have to try and fight with the intake plenum to get oil into the engine.
Old Mar 26, 2004 | 08:10 PM
Phrogman46's Avatar
Phrogman46
Well you learn some thing new every day
shaneinga
Dec 29, 2018 02:04 PM
Jssuperman
General Automotive Discussion
Feb 14, 2017 01:17 AM
SuperTruckUSA
Vendor Specials, Discounts, Product Announcements & Group Buys
Jan 13, 2016 10:31 AM
FarmwomenMoline
4 Cylinder Engines
Oct 23, 2015 02:46 PM
Rusty_Old_F250
Sep 13, 2015 09:20 AM
