- ABSOLUTELY STUMPED
- Tractor style exhaust.
- Dizzy Wiring
- I6 Swap
- Cooling trouble
- Steel vs. Nylon fuel lines
- DUI dizzy
- 300 massive oil leak
- Is stock intake and efi exhaust manifold possible
- rpm, timing cutting in/out high speeds
- Exhaust Manifold Leak?
- 1993 Ford 4 X 4 A/T Engine Swap
- Help
- Out with the 223, in with the 300....need some advice
- New Carter YFA
- '78 300ci valve adjustment
- craigslist carb find if anyone's interested...
- Best realistic highway mpg with a 6cyl ?
- stuck after manifold and carb upgrades!
- Where can I get Ford Part Numbers....?
- need some parts help
- What kind of Carter is this?
- T5 to 223?
- Underside intake heat. Finally...
- Big Cam Shaft is in, now torque convertor or shift kit?
- need bolt style rockers, cant find
- Oil Dipstick length
- 300 torque potential, reliability, gas mileage
- Weird tach/stalling issue
- Window trim
