- 302 Diagnostic Question
- checking enginre temp.
- Big Motor Swap
- Vacuum readings on 351W
- harmonic balancer
- Towing w/ high gears
- need new engine
- diffrent water pumps
- Distributor install problem
- 1992 F-150 ENGINE SWAP FROM 302 TO A 289 CUBIC INCH.
- 351 OR 302 in 78 E150 ?
- wore out distributor gear after 10 miles on rebuilt 302
- building up a 289
- distributor vaccuum
- Stock HP ?
- 351W-460 swap
- cylinder head casting #
- clevland heads
- ID# Info on 302
- amount of oil in a 302
- rough idle in 5.0
- What size pipes for 302?
- Engine Swap
- Id'ing my 351
- 221/260?
- What year 351w will replace my 88 351w the easiest
- Cleaning Fuel Injectors
- Using a 351W... Your thoughts and suggestions
- Coughing 302
- Synthetic Oil in rebuilt 302
