- compression differences on a 302 vs a 351
- Can we conver 89 302 fuel injector to carb?
- 302 Slow Surge Idle, Oil leak, and Overheating!?
- 5.8L swap question(s)
- White Smoke - Unconventional Setup Help
- Oil pan Insallation gone wrong!!! 351W
- Loading Up?
- E3 plugs
- what vacume readings????
- There seems to be a cooling problem
- 86 302 starter for 70 302 will it work.
- Rusted off sparkplug problem
- plenum Torx T40 - how I did it
- what you think about this engine?
- BOSS 302 clone?
- 351W...My next build, DUN, DUN, DUN......
- What 302 engine do I have?
- High Idle after carb rebuild
- 302 upgrades
- Will 93 351's intake with fuel injector fit 89 302?
- Results from mild 351.....
- 351 with impropper flywheel
- 351W choking.
- D20E vs. E7TE
- 351 in 1993 f350xl it make noise
- 66' 289 heads on 91 302?
- 351w teardown (or: watch one thing lead to another)
- which cam
- 351w or 351c which would you use?
- 351W Coil Question
