- 1980 302 with exhaust leak, port shape?
- 351W stroked to 393 "recipe"
- Difference B/W 351W & 351W HO?
- Whats my C/R!
- Gt-40 heads vs.E7TE vs. 1968 289 heads.
- seized up engine NEED HELP!!!!
- surging problem
- GT-40 heads I.D.
- About to change rear main
- Valve stem clearance
- A mocha in my oil pan
- replacing motor
- Collapsed lifter? Bent pushrod? 1980 302
- 302 Flooding bad
- 331 vs. 351
- 302 Starting problem
- 5.8 with codes, codes
- Windsor is very sick
- 302 coil/distributor problem
- Ignition Module Replacement
- New Engine
- Thermostat temp?
- Oil Pressure Problem
- one exhaust manifold or two?
- When did the 5.0 factroy roller block begin?
- engine question
- harmonic balancer?
- White Plugs!
- Electric Superchargers on Ebay!!!!!!
- 94 302 Tune up questions...
