- camshaft and distributor
- 302 Measurements
- Mating flywheel with converter....
- 302-351 swap and rebuild (in progress)
- harmonic balancer bolt question
- 78 351w flywheel on 68 302
- 302 Motor mounts...
- Pulling the old engine block out of the 92 F-150
- 289 Build
- cam specs 1988 f150 302
- Buy or Rebuild
- no spark
- Putting a 77' distributor in an 83'
- 302 vibration
- cant get 302 to kick over
- Max cam lift in a stock '76 302?
- Last year for the 302?
- 88 EFI 5.0 Distributor, in Carb 5.0?
- 302 oil level sensor
- ford 351w problems
- Odd sound while holding speed.
- Pushrod check?
- Building a fuel efficient 5.0 or 5.8 V8, stroker? supercharger? Need help!
- Anyone ever side-gapped their plugs?
- 1988 5.0efi Hp/tq?
- 1989 5.0 fuel injection conversion to carb
- Frozen 5.0
- How to change te freeze plug?
- Low Budget 302 Rebuild.
- 1973 302
