- 5.8 help needed
- 88 5.0 SD
- 351c?
- Can you identify this motor from Jegs?
- Looking for a new 351w
- carb. problems
- '72 289
- Knock knock goes the pistons on my 347 will lucus oil help?
- 650cfm vs 600cfm
- 5.8 motor ideas
- engine dies with front tank selected
- Oil pumping out through dip stick
- blow bye
- starts and revs but doest idle
- engine decal help
- Carburator Tag Info Needed !
- GT-40 heads
- low compression?
- 1991 5.0 F150 engine with gt40p, cam suggestions
- Rough idle ... sometimes F150, 302
- 351w rip off?
- need some advice for my 5.0
- What and where engine identification
- 5.8 engine and trans swap
- 1990 5.0L high idle??
- white chalky stuff...
- Bad lifter or something more serious?
- oil pump drive
- 92 f-150 5.0....what's it got and what should be done?
- 77 351W cam replacement rocker question
