- turn signal flasher--1990 F-150
- Do these cylinder compression numbers mean anything to anyone??
- Broken vac line on 85 E150 302 manifold...
- 351W Timing advance specs
- choke?
- Head and Cam swap.... Results are in!!!
- Blocking exhaust ports on 302 intake manifold
- help w/timing on 94 351w???
- Dissapointed at the Dyno - 351 W
- Help.......broken pushrod!!! Kinda long.
- Compression in stock 302
- 302 Swap
- starting problems (302)
- 351w Heads AARRRGGGHHH!
- ignition timing
- More pulling power
- oil pump priming question
- diagnostic codes 327,328,332
- Installing headers on a 94 F-150 5.0
- edelbrock carbs
- strokin' the 302
- Motor I.D
- cam specs?
- Is my carb screwing me?
- M5R2 to T5z swap
- 302 Valve Springs and Seals Replacement Help
- 302-oil in the air cleaner area
- An extremely simple question
- 351W Dieseling
- 1994 351 specs
