- High Compression problems
- Rolled 5.0
- 302 Engine Question???
- 351W and Edelbrock #2181 w/ 2bbl
- head and valve question and head gasket
- Good heads for 351W
- Rear Main Seal Leak on 302.
- Running weak then rich!
- '79 302 should I overhaul it?
- 5.0 with GT40p heads?
- broken valve or ???
- Windsor tuning issues
- Knock on Cylinder #3 related to Cylinder #7 ???
- Mexican Block 302
- #3 Closing the Gap: The mystery
- severe loss of power
- 393 stroker problem
- 302 blocks are they all the same!
- swapping 4 speed to automatic
- oil&dipstick assembly
- Knock in brand new engine!!! Help diagnose please.
- march aluminum pulleys
- Total Timing A 302!
- 351w performance q's
- swapping over to carb :-)
- Frank discussion about PROVEN and reliable engine mods for the 302,351 small blocks
- Casting Numbers
- New 302 running rough....
- 302 cam into 351 ??
- vacuum advance or mechanical ??
