- ford ho ?
- do i have a 351?? what yr?
- trick flow?
- I think I can make the AOD work with the Edelbrock carbs!!!
- MSD Ignition died
- Can't marry the trans to 302
- Windsor Stroker
- 302 doesn't like to run
- 289 questions
- what do I need to take one engine out and put another in
- 351w heads
- simple question from a simple mind
- 351c
- engine removal question
- My first engine rebuild ,Please help !!!!!!!!!!!!!!!
- compression ratio of stock 1990 351w
- knowledge
- stock spark plugs
- carburetor
- have any of you gone from EFI to carb on a 302?
- Casting Numbers at the rear of 302 block
- 351w hmmmmmmmm?
- 462
- 351w Performance Heads and Intake
- Electric fan
- 351w spark plug wire installation
- stock 302HO mustang cam, good for a truck?
- 289 mods?
- High throttle whine in 351w
- anybody have info on 289s
