distributor vaccuum
Old Jun 11, 2001 | 11:19 AM
stevieray's Avatar
stevieray
distributor vaccuum
I need to know where the distributor vaccuum should come from on a 83 351. It is currently hooked up to a carb port that has no vaccuum at idle(above throttle plate?) This is an Edelbrock carb on an Edlebrock aluminum manifold. Is this the correct way to supply vaccuum to the distributor? This moter was modified before my getting it so I do not know if this is correct and none of my manuals show how to do this (odd). Thanks for any help I can get.
Old Jun 11, 2001 | 01:26 PM
stevieray's Avatar
stevieray
distributor vaccuum
Got an answer to the vaccuum question from an ex ford mechanic, He says that late model smogger motors with vac. advance use a ported supply, i.e. above throttle plate.
Franklin2's Avatar
Franklin2
distributor vaccuum
The way you have it connected is common for most Fords. You can experiment by hooking it to manifold vacuum, but it requires resetting the idle and idle mixture screws and may or may not work better for your application. Most of the time it will work better with the ported vacuum, especially with an auto trans.
Old Jun 15, 2001 | 04:45 PM
bluemustang's Avatar
bluemustang
distributor vaccuum
On my Edel carb it has a ported and full vacuum, on the front the left one is the Ported and the one on the right is the full. That is the only two I have on my #1405 card. You could call the tech support line its on their web site.
Old Jun 15, 2001 | 09:21 PM
Franklin2's Avatar
Franklin2
distributor vaccuum
