- Lifters
- '88 351w Compression test results, specs?
- Vacuum Leakage Around Intake?
- '83 302 running rich
- 351W or 351M
- Valve cover gaskets
- EFI to Carborator?
- 78 302
- "302' and towing
- Crossover pipe on heads?
- Swapping to feul injection.
- Motor runs strong when cold then falls flat when warmed up
- 4 barrel intake manifold on 302
- Codes 33 and 45 - EGR and AIRD
- 351w timing
- Cleaveland Heads
- Auto tranny to manual tranny swap
- C80E-6015-A
- MSD timing
- PAW block kits
- Broncos in CA with 351w mass air in 95 or 96?
- EGR position sensor
- 1996 351 FI Missing below 1500 rpm help!!!
- I would shoot it, but...
- attn: carb and timing masters
- Hey TorqueKing- What's Up???
- 300 i6 to 351w swap ?'s
- 1994 EEC codes
- excessive exhaust
- turn signal flasher--1990 F-150
