- Timing
- What to get with my tax money?
- 89 302 EFI swap to Carb
- Carb & Intake change -worth it?
- Dist Cap/Ign. Wires: Brand Preference?
- Another oil psi question from someone else and a hesitation question as well.
- 78 302 firing order?
- 1969 2v heads
- No oil pressure (302, '79 F-150)
- catalytic convertor
- tapping noise?!?!?
- Knock After Timing Set Install
- 1985 302 heads?
- 289 build suggestions
- 351w HO
- 351w heads
- Would these be fair assumptions????????????
- Early 90's 5.8l
- 1990 F150 302V8 mileage
- 302 recommendations
- engine bogs, then wont start.
- 351w Compression
- mounting flywheel
- engine reprograming
- Wanting to put a 331 stroker kit in 302
- EFI 302 erratic idle when cold
- 351w overheated Help
- Valve Covers
- Is Offenhauser 360 manifold good for a 4x4
- 1984 Conversion Van Oil Pressure Sender (Gauge)
