- 347 horse power and torque ?
- engine build & swap in process
- stroker kit ??????????
- Intake...Is it good for anything?
- Final check on build
- Stripped drain plug - 351W
- Stubborn Lifter
- 351w intake manifold choice's and other questions
- bolt on parts
- Edelbrock intake and cam combo
- Valve spring compressor
- stock heads ported ?
- Timing Chain Cover Corrosion Protection
- 351W and 351W HO
- What is a wiped lobe?
- Hard starting once warm
- Moisture in engine
- EFI Camshaft guys...
- water pump on 302
- 351w cam
- Intake casting number D3AE-9425-CA
- Intake Manifold Swap Smoking
- identifying engine 302 or 289
- 5.0 for my 88 Bronco
- 5.0 info question
- MAF meters
- 5.0 intakes?
- 5.8 idles ok, but stalls when the trying to accelerate
- More exhuast quesions.
- oil pump replace 351
