- Question on head bolts for a GT40...
- 302 or 351?
- Optimum fuel Pressure for 24's
- Eliminating the smog pump...
- Engine gasket kit question...
- What is going to be required...
- Timing Chain Replacement...
- is a cam designed for a 302 much more mild in a stroked 351 w?
- Explorer GT-40 lower intake question...
- big problem with getting 302 to fire
- Throttle body spacer?
- Throttle body size on 91 F150 5.0?? Why dual throttles??
- 351W, any 'on the cheap'/'free performance' type tips?
- Valve covers question...
- 289 rods in 302?
- windsor comparison 302 vs. 351 vs. 392 for gas mileage
- Where are the timing marks on a 351w?
- dumb question, what rockers do i have?
- so ordered my stroker kit today
- Help me pick a cam
- 5.0L oiling upgrade?
- 351w to 393 cylinder head suggestions
- 600 cfm carb secndaries not opening
- when building a 393 do you have to send the rotating assembly out to be balanced
- sudden loss of oil pressure - 302
- 351w to 393 or 406?
- exhaust manifold on 351w to 302??
- piston questions
- compression of a 393 with flat top pistons?
- cam shaft for a 393?
