- Ignition Timing?????
- 5.0L wouldn't turn over by hand...help!
- cant find casting number?
- Ideal Timing Curve, stock 302
- 5.0 and aod swap
- question on valve cover "load spreaders"
- 302 advise needed.
- '70 351w "4bbl heads"
- 92' 351 Windsor EFI
- 351w heads
- Does anybody use starter shims on a small block windsor?
- 1978 351W build....
- 5.0 serpentine belt walking off crank pulley
- High oil pressure in 289
- Changing distributor gear
- 289 Heads
- 289 Heads
- serpentine swap
- Comp Cams Thumper series cams?
- Need help or advice with starter problem
- Engine Stumbles on Turns
- need a little help with my latest project. . .
- 1.7 roller rocker install lifter preload?
- 1988 302 van wont start
- 351 EFI swap
- Valve cover gaskets...which are best to use?
- my 347 stroker thread
- Help Getting new cylinder heads have a few ??'s
- gt40 intake
- 408w build-up, anybody got desktopdyno??
