- New manifold and it runs worse!
- 1st timer here
- 302 buildup (questions for doing so inside)
- 302, cam question
- carb?
- 351W timing set
- 5.0/5.8 EFI Hybrid or Performer 5.8 EFI Intake?
- broke block
- Another 302 took a poop? And head gasket, seal questions
- help id block
- 289 Vacum at idle ?
- '94 F150 302 Low Idle Problem
- 393 Pistons?
- head question
- Transmission won't SHIFT-1979 302 c6
- carb question
- I have decided to go with my Clevor idea
- intake manifold
- electric fan question. 94 F-150
- 96 heads
- Aluminium heads
- camshaft timing chain sprocket clearance
- A/C York bracket#
- 351W Replacement and MPG
- Camshaft Options (Speed Density)
- Best carb for 302
- New Edelbrock Intakes for Cleveland type heads on Windsor blocks
- 351 Ho ?
- crankshaft, camshaft timing
- Coughing engine going uphill
