- Stock 302 valve springs or.....?
- Upgrades to a 302
- lots-o-gas
- stock 351w rocker arms
- 5.0 stalling on the down shift
- DurasparkII shaft lengths
- just got a 302
- 302 crank on a 289
- Bad mileage no power backfiring
- 351W Performance
- 351W cam in an early 302?
- Need assesment on engine build
- "You can't hurt an engine if there is no load on it"
- Badly overheating 302.
- 351 explosion
- 1990 351W Charging problem
- 351 rpm range
- Carb ID
- 351w deck height
- What's the word on carburator spacers?
- snapped intake manifold bolt in 302..now what?
- What to do with 351w EFI from 88? Offroad. Newbie
- what should I do with my 302?
- 5.0 loses fire irratically
- HIPO "stock appearing" windsor intake
- 302 in a ranger?
- Odd carb off of an 85 351
- Cost of machining
- Main and Rod Bearing Question
- E150 has 351W with 302 setup, save the carb?
